- MEXICOWANDERERExplorerDon't give up mike-s if you remember addresses, you're not a goner - yet...:)
- mike-sExplorer
RedRocket204 wrote:
Nothing new. I think that happened a long, long, time ago. Apparently, the Mexican anti-dementia drugs don't work.
Too much Tequila RedRocket204 wrote:
Yes and apparently it is ice cold ;)
Too much Tequila- MEXICOWANDERERExplorerLike Colorado has an eight day no sun hurricane (?) Very easy to rack-up an -800 hour deficit with 24' linear side by side freezers running. Would like fans, etc.lights, etc.
- RedRocket204ExplorerToo much Tequila
- Well then what is the point of a battery if you can't make it through the storm?
- mike-sExplorerNo true Scotsman would post in netkook broken English.
- MEXICOWANDERERExplorerNever have seen a generator that needed sunscreen
Have to keep running around with the panels to find the hole. - MrWizardModeratorwhy ? it only produces power when the sun is out
and 13.6v is not going to do the proper battery charge - pnicholsExplorer II
MEXICOWANDERER wrote:
It isn't a REPLACEMENT for a converter -- it is a battery CHARGER.
David,
Why can't it also function as a converter if you bypass the Intermatic (or remove the Intermatic's trigger clips) and set the Trace to 13.6 volts?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
