pianotuna
Apr 06, 2018Nomad III
While you are correct that a heat pump is not as efficient as resistance heating, the end result from using the pump technology is more BTU's of heat transferred from outside to inside the heated space than a resistance heater drawing the same number of watts.
That is because the resistance heating has to create BTU's, whereas the pump merely moves them around.
Ductape wrote:
Electric resistance heating is not more efficient than a heat pump. And the EPA is smart enough to figure out that HVAC impacts fuel economy. Radical concepts, I know. ;)
