time2roll
Feb 18, 2014Nomad
GD calculator says you lose .8 volts with #10 and .5 volts with #8 with 25 amps flowing. #10 is minimum for ampacity IMO.
Say they are 18v Pmax panels you will still have 17+ volts hitting the controller so I would call it good. #6 would be killing it but could work after the controller if using the same coil of wire.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
