CA_Traveler
Feb 18, 2014Explorer III
smkettner wrote:This is good feedback.
GD calculator says you lose .8 volts with #10 and .5 volts with #8 with 25 amps flowing. #10 is minimum for ampacity IMO.
Say they are 18v Pmax panels you will still have 17+ volts hitting the controller so I would call it good. #6 would be killing it but could work after the controller if using the same coil of wire.
A better analysis would involve knowing the panel specs, each panel to combiner wire length and then the actual length combiner to controller and controller to batteries.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
