BFL13
Feb 19, 2014Explorer II
smkettner wrote:
You will not get Voc (23v) at max amps. Closer to Vmp (19.1v) to figure losses from regulating voltage.
Still plenty of voltage to practically ignor wire size from panels to controller.
Same idea, but just to clarify, you get max amps (rated Isc) with battery voltage under 13.5v. (IV curve on a "12v" panel) When doing that, my rated panel Voc of 21.9 is more like 20.3v measured at the array due to heat loss on Voc.
I am unclear on what panel voltage is when battery voltage is rising through 13.5 while being charged with PWM. ISTR panel v= battery v adjusted for v drop?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
