CA_Traveler
Feb 19, 2014Explorer III
Clipping is based on Vmp and would be 14.4/19.1 = 25% at 70F for a flooded battery. About 15V or 21% for colder temperatures. Also less for equalization but that is normally infrequent.
So there is a 25% loss of panel power or the 150W panel will only provide 113 watts of power to the battery.
The Morningstar MPPT-45 has 92% efficiency or 138W from the panels. Wire size with parallel panel wiring with MPPT would be a much bigger concern than with a PWM controller. Serial panel wiring is much less of a concern with MPPT.
Add 3% MPPT serial wiring loss and you have 11% efficiency loss.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
