Salvo
Feb 19, 2014Explorer
How do you know there's still plenty of voltage headroom?
You know that voltage drops about 0.5% per deg.C rise in panel temperature.
If you go with a 2% cable voltage drop, voltage at the panel must be minimum: 1.02 * 14.7V = 15.0V
If the panel temperature rises 40C, then panel voltage at full current must be: (1 + 40C * 0.5%/C) * 15.0V = 1.2 * 15V = 18.0V
Bottom line, this panel will not output close to Isc current when panel voltage is at 18.0V. Charging current will taper long before battery reaches 14.7V. It will probably taper below 13.7V.
The cable sizing exercise boils down to when you want tapering to begin.
Sal
Sal
smkettner wrote:
You will not get Voc (23v) at max amps. Closer to Vmp (19.1v) to figure losses from regulating voltage.
Still plenty of voltage to practically ignor wire size from panels to controller.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
