Salvo
Feb 19, 2014Explorer
My main point is that cable size does matter, even with pwm.
You get diminishing returns when you go bigger and bigger in cable size. Less than 1% drop makes little sense. Greater than 3% gives a significant performance hit where tapering starts. 2% before charge controller and 1% after CC sounds reasonable. If you got money to burn, go straight 1%.
Sal
Sal
mena661 wrote:smkettner wrote:X2 Sal, you mentioned 2% voltage drop. Was that an example or do you feel that is a minimum requirement? Thanks.
Sal, what wire do you recommend?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
