BFL13's avatar
BFL13
Explorer II
Mar 20, 2017
Panel Wattage Rating Question (Midnite Mystery?)
I am confused about how they do the panel wattage at 12v vs 24v for a controller.
EG, the usual blurb seems to be that output wattage rating for an MPPT (EG Morningstar 60 amper is 800/12v and 1600w/24v for your array.
I don't understand why they have that for output when the array is input.
However, I gather ?????? that the controller has the same amps limit (self -limiting) to 60 amps no matter what the battery voltage is, so if your battery system is 12v then you get 12 x 60 = 720w as your limit (800 here, so amps limit must be a touch higher?) and with 24v system, you get to have 24 x 60 = 1440W of panels except they allow 1600w.
Similar with many other controller brands which have twice the panel wattage allowed for 24v system (meaning battery voltage AFAIK) than for 12v systems.
Then we get this Midnite Mystery--
http://www.midnitesolar.com/pdfs/spec_sheet_classic.pdf
Where the output amps is less for higher voltage systems. So what is the rating for panel wattage at different voltage systems? You can't double the watts if the amps rating of the controller does not stay the same going from 12 to 24 eg.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
