Cstoliker
Aug 13, 2013Explorer
Chris Bryant wrote:
Did you replace the fuse panel? This unit doesn't have a separate charging circuit, and if it is putting out 13.6 volts, it is fine. There are no relays in it.
Pulling the two 30 amp polarity fuses and the voltage runs around 13.4. When the fuses are out back in the voltage drops to 12.4 (or lowere depending on battery state). Pulling a load and the voltage will increase. Turn on 2 or 3 lights and voltages will I crease to 13.2+\-
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
