Chris_Bryant
Aug 14, 2013Explorer II
Cstoliker wrote:Cstoliker wrote:Chris Bryant wrote:
Did you replace the fuse panel? This unit doesn't have a separate charging circuit, and if it is putting out 13.6 volts, it is fine. There are no relays in it.
Pulling the two 30 amp polarity fuses and the voltage runs around 13.4. When the fuses are out back in the voltage drops to 12.4 (or lowere depending on battery state). Pulling a load and the voltage will increase. Turn on 2 or 3 lights and voltages will I crease to 13.2+\-
As far as I know the two polarity fuses connect the battery to the power supply so they would be the charger fuse?
. There are relays. They switch the internal 12v circuits between battery and converter power. Pointless IMO if the converter was charging the battery's as it should be. Over complicated seams to be the build concept with this unit.
There is no separate charge circuit- the fuses are reverse polarity fuses. This is a "float" type system (not to be confused with float charge voltage), in that the battery is always in the circuit.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
