Cstoliker
Aug 14, 2013Explorer
smkettner wrote:
No matter how much you save fixing the 7345 you are still stuck with a mediocre converter that just slow charges.
Yes that's true too. It says 45 amp is available but at the voltage it seams to put out I doubt it unless I ran the battery's down to like 10v (wich is on the border of no return) Right now we run off an inverter with 4 small deep cycle batteries. I start the RV's main engine for an hour or two at idle to charge them, wich is quieter then the generator also but that V10 sucks a lot of gas.
Anyway the season is almost done so I've got some options to consider, thanks guys.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
