tenbear
Aug 14, 2013Explorer
The 7345 probably will put out 45 amps, so if you turn on enough lights, run the water pump, the fridge, etc, etc it will probably supply the 45 amps to run things.
However, with a voltage in the 13.4 range, the battery will not accept anywhere near 45 amps, so the charging rate is slow.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
