Salvo
Aug 16, 2013Explorer
pnichols wrote:Salvo wrote:
You're measuring somewhere outside the converter. Unless you have a voltage sense line, ...
Sal,
I watch what my 7345 converter is doing - voltage-wise on it's output terminals - when charging my AGM batteries via a four-place digital meter plugged into a regular 12V receptacle located quite a ways from the 7345 elsewhere in the RV. However, since this volt meter only presents a very high impedance ("infinite") load, relative to the battery bank's load, to the 7345 when making this measurement via a receptacle ... what's on the voltmeter just about perfectly represents the actual voltage on the 7345's terminals.
Now I'm confused. I thought you were an EE. Your voltmeter is far away from the converter. You're seeing IR line drops.
I have no idea where the 7345's negative feedback loop sense point is relative to it's physical terminals. I assume that the sense point on the printed circuit board is very close, physically and electrically, to the 7345's metal output lugs ... as it should be and better be.
Assume nothing. It doesn't matter anyways, as you're measuring far away from the converter output.
What I see on this voltmeter is that it is NEVER at or near 13.8 volts when it begins charging the 200 AH battery bank. I interpret this as meaning that the 7345's output, as measured at it's terminals, is for some reason sagging from it's advertised "nominal output value" of 13.8 volts. However as the battery bank charges up, it's terminal output (as indicated via the infinite input impedance voltmeter plugged into a 12V receptacle) eventually rises up close to 13.8 volts.
As the battery charges, current tapers and the IR drop gets smaller and smaller. Consequently, the charging voltage that you're measuring far away from the converter increases in magnitude.
Here's another proof of sagging 7345 output: I've installed all LED lighting in our RV ... and for each LED we turn ON, the voltmeter I use (that I mentioned above) to show 7345 output lowers 0.01 (one one-hundreth) of a volt. i.e. One light ON drops voltage 0.01 volt, two lights ON drop voltage 0.02 volts, etc..
That's no proof. You're jumping to wrong conclusions.
Here then, IMHO are some questions/issues:
1) I don't think that Pulse Width Modulation power supply design technology automatically requires that negative feedback around it's output stage(s) be employed for voltage requlation. I expect that PWM power supplies can be designed, and do in fact exist, with only open ended output stages. Output on these of course would then sag with increasing output currents.
Those type of supplies do exist. They have many different voltage output. Only one of the outputs can be feedback regulated. The other outputs are "slave outputs". Guaranteed, this converter has its regulation on the 13.8V output. I've designed converters for many years for the military, avionics and space satellites and space vehicles. I know them very well!
2) Do the Parallax 73XX line of converters perhaps employ only very sloppy negative feedback to regulate it's output voltage such that a couple of tenths or more volts of sag can, and does, occur under load?
I traced out the voltage feedback loop in the Parallex converter. It does not have a sloppy feedback loop. Again, I believe all voltage drops are most likely due to IR.
3) Two-three years ago as an experiment I think I recall that you did in fact move a 7345's sense point out to the battery terminals to force full 7345 voltage (plus a little more, as I remember) at the battery independent of any voltage drop in the cables between the 7345 and the battery. One of my responses to this was that this would be "dangerous" because too-thin wiring between the converter and battery could then heat up from too-heavy current flow because voltage drop in the cabling would then NOT reduce the current acceptance rate of the battery.
Very unlikely. Why don't you do the analysis. How much does a free running, 20 foot long, 8 awg cable heat when conducting 45A? The cable insulation is most likely rated at 120F.
Cal
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
