BFL13
Aug 16, 2013Explorer II
Off-topic warning----
"By the way, do you have data yet proving that other (reasonably priced) RV chargers in their boost modes in fact are holding 14.XX terminal voltages under heavy currents?"
I posted that they all do except for the PDs, which taper right away so you get 75 from an 80 and then the 75 tapers a bit before going into the big taper once the battery gets up, same as the others do.
The difference is the others hold constant amps at their current limit rating (or a few more amps than that if on short fat wire)
I have posted several ugly graphs showing this for my Vectors, Paramode, and now my PowerMax. Others have posted graphs showing their Iotas and WFCO (when behaving)
However, careful wording is required. The constant amps Stage 1, is when the battery voltage is rising from 12.x to 14.x and the charger is keeping ahead of that by 0.2 or 0.4 volts to maintain the spread.
Once the charger's voltage reaches threshold set point, that voltage is held (except with the Vector) but amps then taper so watts fall off. The highest watts is just before amps taper, when charger voltage has just reached its max and amps are still at current limit. One minute later, amps have fallen so VA is lower. I have observed this using my Vector with a watt meter going, where its draw fell off quickly. This is what allows you to use your gen for something else after amps taper enough.
The Vector exception is that amps taper when batt voltage reaches 13.9 so that is the max watts point. But after that, while amps taper, voltage keeps rising to 14.6 or so.(but VA keeps declining) This keeps the amps up higher while still tapering within the battery natural acceptance rate at the voltage.
Iota converter gets to 14.8 with the initial stage and that gets battery to 14.6, which is the trigger for converter voltage to drop to 14.2 and hold there while amps taper. This is supposed to be more gentle than staying at 14.8 till batts are full.
Not going to fight with tinypic to show all my graphs again, but will add one if I can do it with no hassle :(
OK here is one showing the charger holding "100 amps" (actually a bit more) in Stage 1. This charger is set to hold the absorption voltage constant after it gets there, and the battery eventually catches up.
Camping again in cooler temps, so this time I used Mark's temp comp table that says 14.7v is 15.17v at 42F. I set the voltage on the 100amper at 15.2v and charged away to see what happens.
Bank of 458AH (four 6s) est 15% down so calling it 389AH full, and was at 53% start based on Trimetric AH count and battery "morning voltage"
26% charging rate so tapering at 66% SOC is about right. At 23% rate it tapers at more like 72%.
(charger voltage "hunts" a bit at the high end so I showed the range up and down to represent that--it is a rapid action on the voltmeter. Seems to be how it works, so no problem, just a curiosity. )
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
