Salvo
Aug 16, 2013Explorer
Again, that's just an IR drop within the converter. The converter has a series resistance of about 4 mohm that's outside of the regulation loop. 4 mohmn is on the high side, so in addition to wiring and trace losses, there may also be an emi filter involved.
If the 73xx has a similar internal line drop, then Phil should be seeing a drop of 0.004 ohm * 0.2A = 0.8 mV drop at the converter when turning on a led light. That's extremely insignificant.
Sal
Sal
BFL13 wrote:
The Paramode 4455, a follow up to the 7355 in the product line, has these voltage curves which show the sag under load.
https://bestconverter.3dcartstores.com/assets/images/Parallax/4400/4455%20Voltage%20Curves.pdf
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
