Salvo
Aug 18, 2013Explorer
Not correct at all. The new 1N4148 diode clamps output voltage. If cable resistance is high, then current is limited to less than max.
Instead of making wild accusations, why don't you do some analysis first, as I suggested before. The whole charging system is probably protected by a fuse already. The size of that fuse is usually sized to protect the cable we're talking about.
You keep bellyaching about voltage sag in your converter. Make the mod and you'll have no more sag. You'll see a 70% performance gain.
Sal
Sal
pnichols wrote:
Here's a simplified explanation of a potential danger in using a circuit modification like this without the proper charging current flow constraints: His modification will force full 7345 output voltage (as set by the error circuit parameters and components) unto the batteries' terminals REGARDLESS of the gauge of the wire between the 7345 and the batteries. Whatever the batteries will accept, current-wise, with full 7345 voltage (as set by the circuit parameters and components) onto their terminals is what will flow through this wire regardless of the size of the wire.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
