pnichols
Aug 19, 2013Explorer II
Sal wrote:
Here's a quiz question for you. At 45A, what's the largest gauge cable that will start a fire? We'll assume if you don't provide an answer then it's not an issue.
Let me guess ... since I'm 900 miles from home involved with a serious family health emergency and have no desire to look up wire gauge tables: How about the kluggy/cheap thin wiring in some RV's installed by the "high tech" nearly-engineering-less motorhome manufacturers? Maybe 16 awg might (eventually) heat up enough when carrying 45 amps so as to start a fire (eventually) ... perhaps even 14 awg might be a concern (eventually).
Also ... small wires contact connector surfaces in smaller cross-sectional areas than large wires do ... hence small wires carrying high currents can cause excessive heat around and in connectors more-so than larger awg sizes can. This may be especially a concern if the connectors with the small wires in them are subject to some corrosion, as is certainly the case in RV environments.
Again, without going to wire gauge tables, - I can't help but wonder why 15 amp residential circuits must use wiring no smaller than 14 awg and why 20 amp residential circuits must use wiring no smaller than 12 awg?
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
