Cstoliker
Aug 24, 2013Explorer
KJINTF wrote:
That's GREAT news - Sure is a good feeling when you can fixx it by yourself
No need to toss it in the trash and waste another few hundred $$ on another unit
Beer - I like Miller Lite
If ever in west central Montana stop on by for a few cold ones
300mvolts is good - When the current drops a bit the volt will as well - Not sure if you saw my post on MS TS-60 MPPT and took a look at the volotage drop from the controller to the battery
again congrads on a job well done
Same for you if your ever in upstate NY. But I can't imagin why you'd want to be:-)
It's great to have a forum where technically minded people can speek without dimming it down and get real answers. If I said "duty cycle of a pulse width modulation" to most of my friends they would likly think I was talking about something bathroom related.
Now that the 7345 is fixed I may look into upgrading next season and using the 7345 as a shop supply. Honistly can't think of a better use for it. Seams stable and powerfull just not a great charger. I'm still using a supply I built when I was 13. Using a transformer through a diode bridge and adjustable voltage regulator.-again to my friends at the time those words would conger an image of a bridge that changed in to decepticon robot or some such non sense. Lol. But 24 years later its still working
The mod mentiond above as I can see it could be made to correct a design difficency. Moving the sensor from the supply to the battery's (as it should have been done originally)
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
