BFL13
Mar 20, 2015Explorer II
KATOOM wrote:
Thank you. But really if its a signal stage, wouldn't it eventually cook the batteries in a few weeks or so no matter the weather? I guess I'm confused.
Temperature compensation correction needs to be applied. Proper float voltage at 80F is 13.2, but at 50F it is 13.8
When it is very cold your float voltage should be over 14. So the 7300 does just fine at 13.8 in many climates. When it gets hot out, just check the battery water more often. No big deal.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
