pnichols
Mar 22, 2015Explorer II
full_mosey wrote:
Get the automatic temperature compensating(voltage regulating per battery temperature) Parallax-Paramode-with-TempAssure and spend your time on the R in RV!
The Parllax Paramode 4455 may be a great charger for only certain batteries. Study carefully it's characteristic (somewhat poorly labeled) output curves at the link below and you'll see that it's really only a two-stage charger - with a temperature compensated boost mode and one other temperature compensated lower voltage mode. It would be perfect for my particular AGM batteries, but not so good for many others where their manufacturers recommend that a three-stage (or four stage) charger be used to maintain them.
Here's the 4455 output curves:
https://bestconverter.3dcartstores.com/assets/images/Parallax/4400/4455%20Voltage%20Curves.pdf
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
