BFL13
Mar 24, 2015Explorer II
4X4Dodger wrote:KATOOM wrote:
Thank you. But really if its a signal stage, wouldn't it eventually cook the batteries in a few weeks or so no matter the weather? I guess I'm confused.
The documents that came with my Parallax 7300 clearly state that it will revert to a trickle charge when it senses the batteries are fully charged.
Now this is not to say that the 7300 is as good as most of the new generation of smart chargers that charge batteries in four distinct phases. But I am not sure it is accurate to say that it will fry your batteries.
Parallax has replaced the 7300 (mine is actually a 7345) with the 8345.
That 'trickle charge' is in the amps being reduced. The voltage remains the same at 13.8
The 7300 series has been renumbered but remains the same. No longer made AFAIK. That line was replaced with their newer designs.
Living in a moderate climate, I have no need to replace the 7355 for its Float, but I did have to find a better and faster charger for deep cycle batteries that need up to 15v at times.
If I lived where it is hot, I would need a lower Float voltage. To get that, you can swap to a converter that will do 13.2 which is good at 80F. But some folks see 100F as normal, so what do they do? One way is to not float at all, but let them sit with occasional shots of charging. Or stick with 13.2 and add water often. Or move North! :)
