BurbMan
Feb 12, 2018Explorer III
SoundGuy wrote:
I installed a 1000w PSW inverter in the front pass through storage compartment so we can still use a couple of 120 vac fans and make coffee & toast the same way we always do.
Good luck running a toaster with 2 12v batteries and an inverter. That inverter is going to shut down for low voltage before the first slice is even a little brown.
Fans, device charging, TV, etc, yes, but resistive appliances like a toaster? Nope.
I would put one of these in your gear:
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
