BFL13
Feb 12, 2018Explorer II
BurbMan wrote:SoundGuy wrote:
I installed a 1000w PSW inverter in the front pass through storage compartment so we can still use a couple of 120 vac fans and make coffee & toast the same way we always do.
Good luck running a toaster with 2 12v batteries and an inverter. That inverter is going to shut down for low voltage before the first slice is even a little brown.
Fans, device charging, TV, etc, yes, but resistive appliances like a toaster? Nope.
I would put one of these in your gear:
Well I have no trouble doing it. Of course you have to be very specific about just what the set-up is before saying it can or can't be done.
You do need the inverter to battery wires to be of low enough resistance (short and fat) and you need the two 12s to be of sufficient AH capacity at the time. It is easier if the two 12s are AGMs too.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
