SoundGuy
Feb 12, 2018Explorer
SoundGuy wrote:
I installed a 1000w PSW inverter in the front pass through storage compartment so we can still use a couple of 120 vac fans and make coffee & toast the same way we always do.
BurbMan wrote:
Good luck running a toaster with 2 12v batteries and an inverter. That inverter is going to shut down for low voltage before the first slice is even a little brown.
Fans, device charging, TV, etc, yes, but resistive appliances like a toaster? Nope.
Baloney ... I've been doing this for several years now with just a single G27 supplying the inverter. Yes, if my G27 wasn't at full SOC then the draw down would often cause the inverter to alarm, though it never shut down ... with load support from the truck voltage doesn't come anywhere near close to shutting down the inverter. According to you though we've been eating imaginary toast. :W
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
