harold1946
Aug 22, 2015Explorer
Harvard wrote:Hiking Hunter wrote:RJsfishin wrote:
Series parallel is the way to get 12v from 6v batteries,....has nothing to do w/ balance, or getting double AHs
Balance???? If you believe in it, do it. IMO if batt terminals are kept clean, there will be no measureable difference where you connect the load cables.harold1946 wrote:
Series/parallel is the way to achieve balanced draw from all batteries.
That type of connection will also double the usable capacity, amp hours.
X2
The two drawings are electrically the same for all PRACTICAL purposes at the current levels we draw in an RV.
Yes, but, are they both the same when it applies to a much higher recharge current?
If I am understanding your question correctly then the answer is no.
Whether connected in series, parallel, or series/parallel, the charge rate is the same. Think of it as one very large battery.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
