hedge
Jun 11, 2016Explorer
Parallel vs Series, 10awg wire
My truck camper has OEM wiring for a solar panel, the problem is that it's only 10awg wire. I don't really want to remove the fridge if i don't have to so I'm trying to figure out the best way to just use this wire. The run is about 8-10 ft to the charge controller.
I am currently adding 2 12v 100w panels in parallel but have plans for 2 more.
so the questions...
1. how many amps can I get away with with the 10awg wire? Could I run them all in parallel or would the loss be too great?
2. If I run them in series it seems like the voltage gets pretty high, most DC breakers and switches I've seen (using mostly blue sea stuff) has a maximum voltage of 48V. Do you start using AC breakers once the voltage gets higher?
3. Maybe I could run two sets of parallel and then series them together?
4. I realize that if I go series that I will need an mppt controller, Are the EP Solar controllers ok? I'd like a better one but it's cost prohibitive to get up here in Canada.
Just trying to see if it's feasible to use the OEM 10 gauge wire.
so the questions...
