doughere
Jan 12, 2015Explorer
doughere wrote:
Jumper the 3 pos together (one to the next to the next), jumper the 3 neg together (one to the next to the next). Take pos from one end of string, take neg from opposite end of string. As MEXICOWANTERER sort of pointed out, good connections all around are just as important as the wiring itself.
Doug
This is not actually balanced, and is used usually as it is a pretty good system. If you want to perfectly balance it, double the length of cable between the jumpers farthest form the power take-off, or increase the wire size of the cables closest to the take-off.
Unless you are using some BIG batteries, or some HUGE draws this will work fine.
The most important thing is still CABLE SIZE AND CONNECTIONS.
Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
