LScamper
Jan 12, 2015Explorer
lenr wrote:
" If the analysis is for fun then more information is needed for electrical engineering nodal analysis."
It is fun but also useful for those that want balanced wiring. What other information is needed for a complete analysis. Seems that all need information is there.
doughere wrote:
"This is not actually balanced, and is used usually as it is a pretty good system. If you want to perfectly balance it, double the length of cable between the jumpers farthest form the power take-off, or increase the wire size of the cables closest to the take-off."
That is exactly what I'm saying! The easiest way to increase the wire size of the cables closest to the take-off point is to put another cable of the same length and size in parallel with it. To balance the resistance of the cables closest to the take-off point needs to be 1/2 the resistance the cables farthest from the take-off point.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
