LScamper
Oct 27, 2014Explorer
From this EDN note "Multiple PSUs share load"
Using diodes to isolate power supplies.
http://www.edn.com/design/power-management/4419835/Multiple-PSUs-share-load
The results were disappointing, since they show that in the case of ±1% voltage deviation, 90% of the power is supplied by a single supply. Basically, this circuit is not a good solution for power supplies with more than a few tens of millivolts difference. The problem is that not all off-the-shelf power supplies have output voltage adjustments – especially not the sealed ones. To solve this issue, a circuit was developed to ensure load sharing using off-the-shelf power supplies and components (Figure 2).
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
