greenrvgreen
Dec 29, 2014Explorer
If you haven't tried running both off the Yammie, try it just to see. Do your best to make sure the batteries are fully charged so that the converter draw is taken out of the equation. Because I'm sitting here scratching my head as to why a 4500 won't run two ACs.
If it really won't, then I would get fancy with a manual transfer switch to separate out one of the ACs to an aux inlet fed by a second gennie. Then, you can parallel or go separate, as you choose.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
