Gdetrailer
Aug 01, 2021Explorer III
SHRED wrote:
Is the allowable amp draw about 0.3 amps?
thanks
No. .3A is 300 Milliamps, that will drain any car battery in a matter of a couple of days.
Should be more like .01A (10 Milliamps) or less (.001A (1 Milliamp) and your vehicle should be able to sit for a month or two without being started or charged.
Most vehicles have a "power management" system which is supposed to go into a sleep mode after a period of inactivity which may need investigated. Check to make sure you have no USB chargers or anything plugged into the 12V power ports since those may or may not be managed by the power management system.
Make sure all lights like interior lights (including under hood and trunk if equipped) are turning off (sometimes interior lights get accidentally turned on via dash light control) or your door switches may not be working correctly.
