wnjj
Mar 24, 2018Explorer II
burningman wrote:ScottG wrote:
Not really. One can make a sensible cord up using the correct banana plugs and install a 30A outlet in said cable. That would be just as good as the factory setup. It just takes a small effort and some common sense.
Isn’t that what I said? Only difference being i use a box and not an in-line 30-amp RV outlet, because I haven’t found such a thing, have you?
You suggested the banana plugs as an option, but it’s the only option that isn’t a suicide cord. Regardless of whether you have a 30A female receptacle connected to it, 2 male plugs makes a suicide cord. It isn’t confined to a simple male-male cord.
Pulling all of the amps through the 20A receptacle isn’t thendangerous part because there’s a circuit breaker there to protect it from too much current. You won’t get much more than 20A though.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
