MrWizard
Mar 26, 2018Moderator
Properly wired 'Y' pair into an outlet box
Will not be putting all power thru one outlet on one generator
You are thinking of a jumper between generators
Regardless
The banana plugs are a better idea, as there is no exposed metal should you unplug one , which you are not supposed to do even with the banana plugs
Regardless
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
