Thanks for all the replys. After no help from winegard i fooled with it and got it working myself. first i know when i move i will have to change things and second you cannot not power off the 211z, it has a setting to go into standby after awhile and i disabled that but it still goes off. I started on the eastern arc with no luck then switched to the western arc with some luck, i then switched back to the eastern arc with better luck then talked to a tech at dish, he done something on his end and it is working great now.
