Output voltage can be FACTORY ADJUSTED to meet OEM requirements for various lithium ion battery chemistries and Voltages. Standard L Series voltages are set for 14.6- Volts to meet requirements for lithium iron phosphate batteries. Other chemistries may require different voltages.
The PD9100L Series can be wired in parallel to charge at much higher current rates.
They can also be wired in series/parallel to charge 36, 48, 60, 72 and higher voltage battery packs at high charge rates.
http://www.progressivedyn.com/lithium_battery_charger.html
