Cydog15's avatar
Cydog15
PD 4600 series
So there in only one remote that plugs into the 4600 series. I tried to splice years ago and is a pain in the butt because the wires are so thin and took 3 tries. This remote plugs right in...Kudos to PD for making this available. Remote for 4600 series
  • Have the same one. Cable isn't long enough to go far enough where I could mount it so I just have it laying on the floor behind the converter under the dinette seating. Can't see ever needing to use it but it's there and accessible.
    Same thing with the cable for the remote display on our hardwired EMS. I ended up putting it at the back of a cabinet above the dinette seating and the cable length *just* made it. Would have put the Charge Wizard remote beside it if the cable would have reached.
    It's too bad neither the pendant or EMS remote are available in a flush wall mounted version or have extension cables available.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    PD only makes two remotes.. The Charge Wizard for the 9100 series contains both the 3+stage electronics and the light/switch
    The 4600 and 9200 series already have the Wizard software on board so all you get is the switch and light in their pendant.
    Yes. good deal.
