RJsfishin
Dec 06, 2015Explorer
Make no difference, but it sounds like you maybe think you are up grading from 25 amps battery charging, when in reality you will be up grading nearly the whole 45 amps. That 6300 Mag never did charge at more than 3 amps (could have been optinal 12a but not likely) so you should see near a 100% improvement in battery charging.
On another note, is that 4645 a wizad 3 stage ? Seems like the old ones weren't.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
