MEXICOWANDERER
Jun 18, 2015Explorer
This is why I went to 4-1/2 digit ammeter and voltmeter. Toss out the least significant digit and the meters are both remarkably accurate. With millivolt sensitivity I used DeOxit under the shunt screws then the blue preservative. Yes it made a significant difference in readings. Yes the meter lead connections are soldered. I want to know when my 31 is getting into the 1.0 ampere area. When things heat up I will modify float voltage values. Bulk charging to 14.4 must also be adjusted for temperature of the battery. Mine can gain six F measured at the posts. This encourages me to adjust bulk charge max to 14.2 remember my system instantly goes to max voltage regardless of SOC.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
