  • lbzya wrote:
    KJINTF wrote:
    It's a simple modification to increase boost voltage from 14.4 to 14.8 or almost anything you desire. Pin #5 of the micro controller is connected to a 32.4KOhm resister - drop the value by several hundred Ohms and the Boost increases - Simply solder a 60KOhm across the resister in question.
    Do you happen to have any pictures of this modification? I am going to purchase a pd9270 from best converter and would like to be able to charge my Trojan batteries at their recommended charge rate of 14.8.
    You could just as well get the adjustable voltage 70 amp PowerMax Randy sells and set it to 14.8 or whatever you like. (EG, at 32F, 14.8v becomes 15.2v to get the same results as 14.8 at 80F) Adjustable is the way to go!
    Also the PowerMax 70 amper is PF corrected so it doesn't take as much of a generator as the non-PF corrected PD 70 amper does.
    However if you insist on the non-adjustable converter version, you might want the PD with its Charge Wizard instead of the PowerMax depending on what charging profile you need. "It depends" (as usual)
    IMO it is a "no-brainer" to get the adjustable voltage converter that can do it all with less generator required!
  • jrnymn7 wrote:
    What voltage do the 9245c's usually max out at?
    14.4v if the Wizard pendent is installed. Otherwise, 13.6v.
  • "KJINTF, the suggested 60k resistor on pin #5 will not change Normal or Float mode?"
    Modified a few of the PD's - They keep a rock solid 13.2 / 13.6 / 14.9 (14.9 is set by the resister size)60K is only a suggestion - you will need to experiment
    Did a similar modification on my WFCO 75amp plus added a remote control which manually selects 13.2 / 13.6 / 14.9 works good to shorten gen run time
  • I wonder if this is a Randy custom modification or if PD made a special batch for Randy.
    I would be curious if amps still sag as PD is known for. Also if this unit will still run on a Honda 1000?
  • It's a simple modification to increase boost voltage from 14.4 to 14.8 or almost anything you desire. Pin #5 of the micro controller is connected to a 32.4KOhm resister - drop the value by several hundred Ohms and the Boost increases - Simply solder a 60KOhm across the resister in question.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
