otrfun
Oct 23, 2014Explorer II
Ron Nielson wrote:Have you tried measuring charge current with a clamp-on ammeter at the battery? With discharged batteries (12.1 - 12.2 vdc) I've found initial charge current with my PD9260C to be roughly 25-30 amps in absorption mode and 55-58 amps in bulk/boost mode. Huge difference.landyacht318 wrote:
It takes time for battery voltage to catch up to converter voltage.
When I set my meanwell rsp -500-15 to 15 volts, then attach it to the battery. The voltage at the mw terminals drops to mid to high 13s and battery voltage is likely a volt under that.
Where are you measuring voltage at?
A clamp on dc ammeter is enlightening. Voltage is deceiving.
I am measuring voltage where the battery cables enter the PD9260. I have 2 other monitors, one of which came with the trailer (with the idiot lights for the tanks) and also a Trimetric 2030 monitor, measuring at the battery.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
