otrfun
Oct 24, 2014Explorer II
Yes it is a HUGE DIFFERENCE and that's why I'm trying to figure out why my PD9260 does not go into boost mode. I have no clamp-on amp meter, but amps do show in my Trimetric. I haven't looked at amps in the Trimetric other to see that they are higher when the converter 1st starts, then tapers off as time goes on. My battery was about 35% discharged, a significant amount. I expected the PD9260 to start out in boost mode, then drop back to absorption rate, but it doesn't.I totally empathize with your frustration. Before I purchased the PD9260C, I tried everything to get the WFCO8955 into bulk/boost mode. It was so frustrating to have to spend almost $200 just to get the bulk/boost mode the WFCO8955 was designed to deliver in the first place.
Do I have to discharge the battery 50% to get boost mode, or 60%, or 70% ??
Anyhow, back to the topic at hand. Seems we started out trying out to determine whether you were in bulk/boost or not, but now it seems to have gravitated towards why the PD9260C hasn't gone into bulk/boost mode on its own.
I believe the Charge Wizard Pendent will go a long way in addressing both of these issues. When the PD9260C is OEM packaged, the pendent is included with the PD9260C. The small pendent (with 5-6 ft of wire) plugs into a small RJ type connector on the side of the unit. It does two things, one, it tells you what charging stage/mode is currently active (LED steady on, bulk/boost; LED blinking quickly, absorption; LED blinking slowly, float), and two, it allows you to push a button and manually change the charging stage/mode to one of your choosing.
The PD Charge Pendent is only $10-$20. I'd recommend purchasing one. That's a small price to pay to know what the PD9260C is thinking--even for troubleshooting purposes. Plus, if you disagree with it's logic, literally, you have the option of changing it. That's a lot of flexibility for less than $20!
My two cents . . .
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
