otrfun
Oct 24, 2014Explorer II
Ron Nielson wrote:Good news! It'll be a lot easier to go into bulk/boost mode with the pendent :)
Finally! Drew down to 11.9, turned on PD9260 and got 14.27 volts within a minute at the device, still only 13.0 volts at the battery itself. 51 amps going to the battery. So I think the device will work if the battery is low enough. And another thing, this is the 1st time I have ever heard the fan turn on. Now I know it works if needed.
You must have a long run of smaller gauge wire to only have 13.0 volts at the battery. Voltage aside, 51 amps is a good, respectable charge current.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
