tenbear
Nov 27, 2016Explorer
All wires have some resistance. The voltage measured at the battery will be the converter voltage less the voltage drop in the wiring between the converter and the battery.
This voltage drop depends on the current flowing in the wire. Ohms law can tell you what the voltage drop is. Ohms law --- voltage = current x resistance. So a current of 10 amps flowing in a wire with a resistance of 0.1 ohm will have a voltage drop of 1 volt.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
