tenbear
Nov 27, 2016Explorer
You are probably replacing a single stage converter that probably only charged at a less than 10A rate. The wires were sized with that charge rate in mind. Your PD9260 is capable of charging at a much higher rate, especially at the high voltage of 14.4v in the boost mode.
I did the same replacement and I replaced the #8 wire with #4. I know you can't replace the old wire but could you run a larger wire in parallel with the old wire?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
