Matt_Colie
Nov 28, 2016Explorer II
Jim,
Measure the voltage at the converter terminals. It is easy to loose that much on the way to the actual bank.
If you do want to get the full poke out of the 9260, you may have to:
Replace the cables with heavier and copper,
Run both positive and negative instead of trying to use the frame,
Relocate the converter closer to the bank so the run is shorter.
I had to do all three.
Matt in Michigan
Matt in Michigan
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
