BFL13
Nov 29, 2016Explorer II
road-runner wrote:
I haven't seen any mention of the output voltage tolerance. It would be good to have it in the converters specs. I don't see it there. Offhand I'd consider anything between 13.50 and 13.70 acceptable, which is about +/- 7%. With the correct converter voltage being different for different batteries, different installation wiring, and with the battery temperature, I don't see any purpose for much concern over an exact output voltage. No matter what it is, it will be less than ideal almost all the time. If you want perfection, you need voltage and temperature sensing at the battery, and programmable voltages.
PD4600
No Load DC Output Voltage 13.6
No Load Voltage Tolerance +/- .3 VDC
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
