rockhillmanor wrote:
NinerBikes wrote:
oldtrojan66 wrote:
I would not have thought this such a frequent problem, but twice now, only at Indiana state parks I have found loose female receptacle in the pedestal. Each was loose enough to burn the spade on my power cord. I replaced it once, but the second time was only two stops later. Do I need to carry a dozen spare ends? I have worked some with electrical receptacles on ranges and dryers, but then I have access to the house breaker box to change out the receptacle. Can't to that here, and by the time I notice the problem (heat) it's usually too late to call the maintenance people to fix. Any thoughts? Thanks in advance.
Don't camp in cheap, poorly maintained, shoddy campgrounds with poor electrical outlets. Sounds like your state parks are not up on current maintenance for their pedestals.
I full time and it is not just cheap CG's it's all the CG's.
Those outlets are used 1,000 times more than what they were made for........
What you are saying is that campers are stupid and abusive to campground equipment, thereby destroying it, in the areas that you camp. Would that be a fair assessment?
I don't treat my receptacle on my Honda generator like that, and I've had no problems. BECAUSE I OWN IT AND HAVE PRIDE IN OWNERSHIP. There's your sign.
What the hell is your problem?? :?
The problem is yours... what do you expect when you rent anything? Abused, plain and simple. Like the maid that wrecked every single electrical outlet she's plugged my vacuum cleaner into, as well as bashing and scraping the paint off the baseboards with the vacuum cleaner as well. It it ain't yours, there's no pride in ownership, no incentive to take care of.
