oldtrojan66's avatar
oldtrojan66
pedestal receptacle
I would not have thought this such a frequent problem, but twice now, only at Indiana state parks I have found loose female receptacle in the pedestal. Each was loose enough to burn the spade on my power cord. I replaced it once, but the second time was only two stops later. Do I need to carry a dozen spare ends? I have worked some with electrical receptacles on ranges and dryers, but then I have access to the house breaker box to change out the receptacle. Can't to that here, and by the time I notice the problem (heat) it's usually too late to call the maintenance people to fix. Any thoughts? Thanks in advance.
  • j-d's avatar
    j-d
    Explorer II
    I wasn't suggesting we repair campground pedestals. Cheap as 30A receptacles are... is $8 on Amazon...I just might give one away to a campsite that'd install it for me and ease my problems for a week or two.
  • Do not change out the campground receptacle. Make the campground do it or ask to go to another site.
    I do carry a spare male cord body for the rig. I have not had to change mine on the road but did provide it to another RV.
    Yes, normally the 50 amp receptacle is in a little better shape. Using the 50/30 adapter may save some issues.
  • Hi,
    Sounds as if you may also have a voltage drop issues. Do you track the voltage?
    What are you running in the RV?
  • j-d's avatar
    j-d
    Explorer II
    And COMPLAIN.
    Doggone it, those campgrounds are charging to provide a service and they have both the parts and the people to change them out.
    The "fact" (and I believe it IS fact) that people plug their coach in with the pedestal ON and the Coach A/C and Water Heater ON, and Unplug with stuff ON and not turning the Pedestal Breakers OFF, doesn't change your right to expect a proper connection.
    We have to practice "load shedding" at State Parks in Summer. The 15000 A/C plus Converter means we don't use the Water Heater on Electric. Also means that we get to choose one more high-draw appliance like Coffee Maker or Toaster or Microwave... I do MY part. Campground needs to do THEIRS.
    EDIT: In what I'll call a "proper" campground pedestal, the Breaker can be pulled out like you can at home. Then all you have to do is avoid the same "bus" that you must avoid in a home breaker box. Then you can replace Breaker, Receptacle, Wiring, etc.
    But some CG's and Marinas have gone to these space age plastic ones
    that have to be handled live ***OR*** shut the whole loop off. Reminds me of cars. The designers never had do work on one.
  • Standard nitrile gloves when used bone-dry offer plenty of insulation. I toss a rubber mat down and wear plastic shoes. When I switch wires, it is one at a time after I verify their proclivity for polarity and ensure the service has earth ground.
  • 50A plugs are usually in better shape so if available use an adapter. Check with a flashlight and you might see a problem.
Having RV issues? Connect with others who have been in your shoes.24,205 PostsLatest Activity: Feb 23, 2025
