opnspaces's avatar
opnspaces
Navigator II
May 02, 2019
Performance difference between jumper cable and Lithium pack
How is it that my standard automotive jumper cables have very thick wires and the new lithium packs use wires that are comparatively much smaller than the old style cables?
Do they both do the same job of starting a vehicle with a severely depleted battery? Or does the lithium pack only work on a battery that is less depleted but you need cables if it's depleted past a certain point?
  • Chum lee wrote:
    I was totally amazed once when my li-ion portable battery booster actually jump started an older GM V8 diesel with totally dead wet cell batteries. (2-12 volt starting batteries from the factory)
    Chum lee
    There are varying degrees of "totally dead".
    The small packs depend on the internal battery still being partly functional. They also depend on the stricken vehicle being fairly healthy so it will start right away.
    I bet you wouldn't have fared so good if they had gone OPEN.....so that they couldn't help supply any current at all.
    OR if it was -30 F and the engine was about 10 years beyond needing a tune up.
  • Check the actual wire gauge of your jumper cables. Don't be fooled by thick insulation. Copper "looking" cables aren't necessarily solid copper. Far from it.
    In a jumper type situation, its all about the difference in voltage between the jumper battery and the battery being jumped. The new lithium batteries are pretty good at initial surge voltage which helps a lot in a jump situation.
    Chum lee
